Old 03-09-2007, 09:09 AM   #15
KevinH1990
KevinH1990's Avatar
The shape of the windows is different on a 987, so that is at least one point where it won't fit.
Search for threads on GAHH tops and Robbins. They make aftermarket glass window tops for the 986, and there have been quite a few healthy discussions about aftermarket tops.
Starting in 2003, the 986 also had a glass rear window. You could probably retrofit that top, but I believe you would also need the frame and some other components. It might be economically feasible if you could get what you need from a wrecked car.
KevinH1990 is offline   Reply With Quote
