Old 02-27-2007, 09:33 PM   #2
ray986s
its simple...
You can do a straight plug and play with the litronic. No wiring neccesary. If you remove your old amber lights and plug in the lits it will work, BUT only the low beams, no high beam. You can buy the module on ebay and this will only take a few wires to hook up and this will allow you to use high beam feature (the projector lamp will actually move up to aim higher. What I believe you are mis understanding is the non litronic cars, is not wired for the self leveling system (this is when you turn the headlights on you actually see the beam adjusting up and down untill it adjust to the proper level.) As far as you car being a RHD it does not matter because they are wired the same. What I have heard is in certain countries in Europe have a certain requirement if your are retrofitting litronics unfortunately, I do not know what those specific requirements are so better check with your local authorities.
986s sport design pkg, aerokit 1, litronics,deviating seat stitching, guards red seat belts, cf ebrake/shift knob,ssk, sport seats, hard top, full alpine system with 8" sub, mb quart speakers, Champion rg5, Eibach springs, sport exhaust, rear stess bars, custom ecu program, desnorkle intake, euro bumper, rear diffuser
ray986s is offline   Reply With Quote
