Thread: Tire Wear
Old 02-20-2007, 07:34 AM   #10
MNBoxster
Originally Posted by Sammy
I've seen cars aligned with the weight of the driver but nothing to represent a load in the trunks. I would recommend that when you get the alignment done that you ask them to align the car with you in the drivers seat. I wouldn't recommend trying to reproduce your "loaded" weight in the trunks.
Hi,
Good point, but also be sure to have a Full tank of Fuel and the spare and tools in the front at minimum. If you always drive with a greater load than this, then that should be present for the most accurate alignment (with the caveat that if you change this gross weight at any time, the alignment, feel and possibly tire wear will change as well, maybe imperceptibly so, but it will)...
Happy Motoring!... Jim'99
