Old 08-26-2004, 08:49 PM   #16
mrmickeymouse
I would start with exactly what you thought, the cap first.
You could be dribbling fluid from somewhere you would not notice i.e. a hose.
Maybe find a cheap pressure checker, and then check for bleed off.
White smoke would be indicative of a head leak. Bad side is I have seen some seep a little into the chamber which never showed until we did a pressure check of each cylinder.
Unless you have overheated your motor , I would not worry about the idea of a head leak. It seems that is less common.
mrmickeymouse is offline   Reply With Quote
