Thread: spark plugs
Old 02-14-2007, 07:27 AM   #16
porsche986spyder
Originally Posted by MNBoxster
Hi,
The OEM Sparkplug specs are:
  • 2.7L - Bosch FGR 6KQC
    3.2L - Bosch FGR 7KQC
    - Beru 14 FGR 6 KQU
    - Beru 14 FGR 7 KQU
Torque spec is: 30 + 3 Nm (22+2 Ft. Lbs.)
Your car doesn't have spark plug wires in the traditional sense. It uses a Coil-on-Plug and so there's no advantage to using a different wire, such as you mention, nor am I aware of any aftermarket ones even being available. Hope this helps...
Happy Motoring!... Jim'99
Thanks for the info, but what about this. It seems that since the 3.2 has more power that it may run a colder spark plug. Anyone know? And if this is true, would I benifit more by using a colder runnig spark plug on my regular boxster 2.7 that is modified with bolt-on performance parts and a reprogramed ECU/CPU?
porsche986spyder is offline   Reply With Quote
