Old 02-13-2007, 06:45 PM   #3
thenavarro
I think my belt problem may be a tensioner. When I put the socket and breaker on the 24MM bolt and turn clockwise the tensioner moves to the left, however when I release, the tensioner returns but it does not return all the way to the right, in other words if I apply pressure counterclockwise I can move the tensioner further to the right. Does this mean that the tensioner is not retracting all the way to the position it should be in and is therefore defective?
This is without a belt on. I'm just testing the tensioner. If its properly functioning, should you be able to move it to the right by turning counterclockwise on the bolt? Thanks,
Mike PS-Anyone know the part number for a 986 tensioner for a 2001?
thenavarro is offline   Reply With Quote
