Originally Posted by xclusivecar
1)Stay out of trouble and only use stock plugs. This will guarantee true compatability and will come pre-gapped.
2)Double check the gapping of the plugs. Although I have never had one off...by much...I can only imagine its possible.\
3)Jack up side of car, remove rear wheel, remove wheel liner and TADA!!! 3 plugs staring at you. You will need to contort a bit to get the tools in there but it is NOT difficult and you do not do this from the top of the motor access.
--This is a very easy DIY. Give it a try and once you do plug #1 you wil fly through the other 5!
Good luck!
WOW, that does sound easy. I've changed plugs before on my old car. I'm still going to buy the Bently Manual first. But it does sound like I can do it myself. Thanks!
