Old 02-12-2007, 11:12 AM   #6
MNBoxster
Originally Posted by GSRP
Just a follow up on this issue.
I had an independent Porsche tech check out this problem -- he confirmed what the dealer said -- the tranny switch does need to be replaced. I don't know if this is a common malfunction (probably not since the dealer does not keep this item in stock).
I'm having the independent shop do the work since he's about $200 less than the dealer.
-gene
Hi,
Sorry it actually was the switch. Any switch can fail, but it's not too common. Good thing you found an independent to confirm what the dealer told you, especially since he's cheaper. Good Luck!...
Happy Motoring!... Jim'99
