Donv, here is what Sal told me in an e-mail:
"NOTE: Z-8 is EXTREMELY concentrated and can be a little finicky in
hot,
humid weather, but it is definetely worth it...
When applying multiple coats of Zaino polish the same day, especially on
darker color vehicles.. I would highly recommend waiting a couple of
hours before appyling Z-8.
If Z-8 should ever streak,... Just wipe the area with a damp towel and
the streaks will disappear.
Z-8 is extremely concentrated, less than 1/3 ounce will do the whole
car. You are applying way too much. Remember less is better with Z-8...
Z-8 is sprayed directly onto the paint surface.
A small dime size is sufficient for a 2 foot section on the car.
Immediately buff with a 100% cotton towel until dry. You will feel the
surface get slicker and slicker. Turn towel frequently. Repeat on next
section until entire car is finished. Do not let Z-8 dry on car. If Z-8
drys by itself just reapply Z-8 to affected area and rebuff until
completely dry. Then get the sunglasses out.
Remember: If Z-8 should ever streak,... Just wipe the area with a damp
towel and the streaks will disappear
NOTE: Definitely do not use Z-8 spray on a hot paint surface. It is
heat activated and will evaporate too fast and will be hard to work
with.
Although I do not recommend the following... If the above fails... Take
a small spray bottle.. Get Distilled Water and dilute the Z-8. Start out
diluting it in small proportions until it works the way you want... "
