Originally Posted by porsche986spyder
I did that, and now I am regretting it because it did not come with the 2 aluminum bushings that replace the stock plastic ones. They only give you the shifter and no retaining rings, no plastic sleeves that go inside the Aluminum Bushings either. I could use it without the metal bushings, but I figure if I am going to do it, might as well make sure everything is icluded. By the way, I did some research and found out that the B&M is 5% shorter in the throw than the Schnell one. I think that is my deceiding factor. 30% vs. 35%.
I'd be surprised if you can feel a 5% difference.
