Old 02-07-2007, 03:51 AM   #16
EuroProjektzKelvin
Send a message via AIM to EuroProjektzKelvin
Dead batteries
If you drive your boxster say once a month or rarely i recommend Deep Cycle batteries, those battery are meant for long storages usually used on boats.
Conventional battery aren't meant fro storage for long period of time, but you could solve this problem with a battery maintance charger.
For COLD COLD weather, there is somethinc called Cold Cranking Amps abrevated at CCA on the battery. The CCA determines the battery ability to crank the specific Amps ( its what makes your starter turn) in a cold temperature. The higher the CCA the better i recommend 600-650
Have a nice day, if there is grammar/misspelling issue my bad i'm typing this 4 in the morning
EuroProjektzKelvin is offline   Reply With Quote
