Old 02-02-2007, 04:35 AM   #1
porschegeorg
cold or warm oil change?
Guys,
I have my Box in winter storage. It will be sitting idle (with battery maintainer) for about 5 months. Before I get her back in operation in the spring, I plan on changing the oil.
Should I warm up the car with the old oil before doing the oil change? Or should I simply drain the old oil while the car is cold. Keep in mind that I change this oil every year (not every 2 years). I'm not sure if the oil need to be warm so that it flows out easier, or if even when cold, it will eventually all flow out.
I really appreciate your thoughts on this.
Georg
2003 Boxster Seal Gray/Gray
TIP
5000 miles (for some reason I'm proud of this)
porschegeorg is offline   Reply With Quote
