Old 01-26-2007, 05:53 AM   #3
tomk17
Side Marker Light Replacement
I just completed this last week Rondog. Your black car will look much better with the clear marker light as did my Seal Grey. Use the plugged hole in the wheel wheel for sure. Your working blind so to get an idea of the angle the screw driver needs to be at, hold the new light up next to the installed one - it helped me. Basically its the springy stainless steel clip that you need to push on.
See you manual for an overview of the procedure. That "bayonet" clip that holds the electrical connector on was the hardest part. Gotta pry that thing off with the same small screw driver.
06 Boxster
Seal Grey
Bose, Xenons, 17"
http://img144.imageshack.us/img144/8...rivewayic1.jpg
tomk17 is offline   Reply With Quote
