Old 01-17-2007, 12:07 PM   #16
z12358
Originally Posted by SD987
I'm surprised that the way you're addressing what you describe as the "big gap between the tires and fenders" is by lowering the car rather than getting 19 inch tire/rims, which I think is what Jeff Squire was getting at. My previous base 987 had the 17" OEM rims and that gap you're alluding to was horrendous (not to mention that the 17" rim design is pretty uninspiring). I would agree that while not as bad, the gap is still present with the OEM 18" rims you have. The 19" (Carrera S) wheels on my current car eliminate that gap and make the car appear lower (although the rim design remains uninspiring).
The 987 wheel wells are designed to look flush, and therefore more appealing, with the 19" upgraded tires that Porsche sells for that model, just as the 986 with 16"s looks like poo when compare to the upgraded 18" wheels.
Getting the 19" rims will not increase the diameter of wheel (the rim + tire combo), as 17", 18" and 19" rim + tire combos produce wheels of about the same overall diameter. Actually, the diameter of the 18" wheels (rim + tire) is slightly larger than the diameter of the 19" wheels.
The only way to fill out the gap without lowering is by using a larger diameter wheel. This means getting larger profile (vertically fatter) tires than recomended for each particular rim size. This will actually raise the car a bit but will fill the wheel well better. This will also affect the suspension, and the speedo and odometer measurements as they have not been calibrated for these larger diameter wheels.
Z.
'06 Boxster S, 6sp, triple-black
http://i153.photobucket.com/albums/s...05_IMGcrop.jpg
z12358 is offline   Reply With Quote
