Old 01-17-2007, 09:21 AM   #11
Perfectlap
Perfectlap's Avatar
if you are going to do a suspension mod...do a suspension mod.
if you have the means go with a full kit, new shocks and springs. On an expensive car like this I wouldn't consider anything other than coilovers which allow you to adjust the ride height. If you pass up on the coilover kit you are stuck at the ride height which you may not like at all.
I had a very experienced mechanic I once used refuse to install a set of eibach springs on a previous sports car on principle. He said there is no point in having to do all this labor, re-align the car and then face the possibility that the ride may be all wrong. You need to do some proper driving in a similar car with the exact set up you are considering before you pull the trigger.
Also, lowering a car that is often driven on public roads, particular one on 18" wheels and higher, is going to take a toll on your car. All the joints and connections through out the car will slowly start to loosen. The car will start to rattle and before you know it things are starting to break. If your car is a Sunday driver with few miles clocked in a year its probably safe. But if you drive that thing allot know what you are doing. Lowering a car is not a cosmetic adjustment, its a performance mod. Needs to be tested on the road before you make a change that you will be stuck with or have to pay allot of labor to undo.
BORN: March 2000 - FINLAND
