Old 01-11-2007, 11:12 AM   #1
QporscheQ
QporscheQ's Avatar
I didnt drive my car for two months over the holidays while at the same time it was super cold here and the combination of the two caused my battery to die. I tried using a trickle charger to get some juice but the charger decieded that the car was too much load with a totally dead battery and did help at all. It just kept going to "Fault" mode. Onto Plan B. So don’t be shocked if nothing happens with the trickle charger.
I opened the fuse panel to see if my car had the lead in there like people kept mentioning on this board (it’s a '02) and low and behold a little manual fell out with instructions on how to open the hood when the battery dies. I started laughing. Fortunately for me I have two cars so I hooked up the battery from my other car (as the instructions indicated me to do) and my car sprang back to life with horns and lights flashing from the alarm. I popped the trunk and hooked up my "serious" battery charger to the batter and nothing. Battery was dead dead dead and wouldn’t take a charge. I tried jumping off my other car with no luck either. My local AutoZone had a replacement in stock (the guy said they usually only have one in stock if any and only sell a couple a year). I used the new battery to pop the trunk again (I let it close by accident the first time) and swapped out the old one.
A bit of a pain, but long story short if you have a second battery, hooking up to the lead in the fuse panel is really simple.
Q
QporscheQ is offline   Reply With Quote
