Old 01-11-2007, 09:16 AM   #3
MNBoxster
Originally Posted by Boxtaboy
Boggtown is correct, DJ...your manual levers will not work if the battery is out of juice.
Hi,
True, but if you use the 9-volt jumper I described, you can use the Lock/Unlock Tip Switch to open them. These are available from several Auto Parts Retailers and usually go by the name Memory Savers. Usually under $12. See: http://www.drivewerks.com/catalog/shopcart/TOOL/POR_TOOL_CAT439_pg3.htm
Hope this helps...
Happy Motoring!... Jim'99
