Thread: Help please!
Old 01-10-2007, 08:18 AM   #1
MNBoxster
Originally Posted by jmabasa
Thanks to the advice everyones given so far. I just came from the dealer and got a couple of batteries. The light on the key flashes now but it wont lock or unlock the car. I tried other suggestions like putting the key into the ignition but not starting it, taking out the key and pressing the lock/unlock button within a few seconds but nothing. Is there any other way I can get the keyless entry to work or am I stuck now with just locking/unlocking the car manually?
Hi,
I suspect that you may need to get the Dealer involved. The Alarm/Immobilizer is adjusted, programmed by the PST2 Computer at the Dealer. They can tell you what's going on.
But first, does your alarm work when you arm it manually? If not, there is a 10A ATC Fuse in the Immobilizer Module under the Driver Seat. Be sure this fuse isn't blown.
Another possibility is that the Alarm went into Sleep mode (after 120 Hrs. of non-use, the module stops listening for the key as a battery saving feature). Your Key Fob battery may have died and the car went into Sleep Mode. If you change the battery it still will not work until you once open the Lock manually and then switch on the Ignition and/or Start the car. Try that and see if it doesn't correct your problem. Hope this helps...
Happy Motoring!... Jim'99
