Old 01-04-2007, 06:34 PM   #1
Travis
Send a message via AIM to Travis
Originally Posted by jmabasa
Thanks Travis! So if the timer goes to 6 minutes, this is normal? Should I wait for this countdown timer to end before starting the car?
Only if you are wanting to check your oil level, I myself will check the oil prior to a drive while the engine is cold and afterwards when I pull into the garage and wipe the car down after a day's drive I would check it (by that time the oil would have drained back down).
Travis is offline   Reply With Quote
