Mother's Wheel Cleaner is pretty good. If you use it correctly you don't even have to touch your wheels all the dirt is lifted off from the wheels all you do is point the hose and spray.*
*Do not leave it on for an access amount of time,only 30 seconds max then hose the solution off. If you leave it on too long it can stain the wheels (I beleive it has some mild acid in it).
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
