Originally Posted by jci-joe
Also, what was involved with the footwell lighting hack? This would be great. I still can't believe a car that cost over $53k only has one interior dome light.
Missed this one... I used two triple LED lamps and mounted them under the dash, the wiring goes under the dash, up the A-pillar to the dome light. Once you get there you can either tap in with wire taps or solder the ends of the wires to the light. It really is quite easy, I have some spare lights if you want some then all you need is a couple of yards of wire.
This picture makes them look much brighter and more defined than they really are because I had to take it with a long exposure so you could see them, the effect is pretty subtle and I really love it.
