Old 12-24-2006, 06:43 PM   #22
Rodger
Can someone tell me definitively what two tools are needed to remove the drain and fill bolts on a 2000 Boxster S with a 6-speed trans?
I've got the 16mm triple square with the hole and a 17mm allen. I've heard there may be a different tool I need.
Additionally, where the 17mm allen is needed, is there a clearance issue? I ask because the allen socket I have is about 4" long. If it's for the drain, no problem. If it's for the fill and the clearance is tight, I'll have to cut the allen tool shorter.
http://i19.photobucket.com/albums/b1...dingAvatar.jpg
Sold September 4th, 2007.
Rodger is offline   Reply With Quote
