Originally Posted by z12358
So how did you calculate that the "little more" heat will be compensated by the "little stronger" oil cooler? By assuming little = little?
Yep. The "S"/996 oil cooler is almost twice the size of the base Boxsters. I talked to someone that did it and he said it was a noticeable drop in temp when the car is pushed,otherwise the car runs about the same temp.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
