Old 12-16-2006, 05:08 PM   #5
ohioboxster
ohioboxster's Avatar
Originally Posted by wvicary
I've installed hundreds of universal O2 sensors with no problems.... maybe you just had a defective one. As for the reference air supply, Bosch states that it gets it sample from the main electrical connector. They also recommend not using anything like dielectic grease as this can block the air from the sensor wire.
I've never heard or read of adding holes at the connection site.... I would think moisture would migrate into the wire and casue corrosion.
I have four 02's for sale if your interested. I can tell you my cel is off and I dont have any codes now. Have you installed hundreds of 02's on Porsches? If so which ones do you use?
2002 TT
ohioboxster is offline   Reply With Quote
