Old 12-13-2006, 05:35 PM   #1
boggtown
Guest
Posts: n/a
I re seated it another couple times and no luck. Even took out the connector and re seated it, no luck. I have run out of luck I guess. Does anyone have a diagram for that connector so I can see which pin is the low beam and ground (so I can check voltage). Also, if that doesnt work, should I splice into another light so it goes on or just take it to the dealership?
