Originally Posted by Bavarian Motorist
So they are track accepted...generally speaking?
First things first. Sign up for membership to your local pca.org chapter. Then sign up for a Driver's Education event with them next spring. Depending on high tall you are and what the rules are for the local chapter you will figure out if you satisfy the track requirements. Typically if you pass the "broomstick test" (a broomstick resting on the roll bar and the windshield pillar cannot touch your head with a helmet on it) you should be fine. I'm 6ft tall and I pass with no problem.
