Old 07-10-2026, 06:02 PM   #1
alexpinson5
Raspy noise when engine coasting down?
Hi all,
Trying to diagnose a noise on my 2000 S (~42k miles, manual). When the engine is coasting down I get a raspy/sucking/grinding noise. From inside the car it sounded like brake pads slightly dragging over the rotors but I also get it when the car is stationary.
If I rev up to ~4k RPM and take my foot off the gas, there's a slight pause and then the noise starts until RPMs fall. It is not present at idle. Most noticeable when in 2nd gear and coming to a stop, but doesn't matter if the clutch is in our out or which gear. The slightest touch of the throttle makes the noise instantly go away. Half a millimeter in and it's gone. It's also not present on a cold start but appears relatively quickly as the engine warms.
Because of that brief pause before the noise starts I assumed one of the clutched pulleys on the engine - I replaced the alternator pulley which *had* failed, and that solved some belt squeal I was getting when doing 3-point turns, but did not fix this noise. The AC compressor pulley feels OK and clutches on/off with the climate control button. All other pulleys feel good.
IMS has been done, and due to the relatively low miles I'm hoping nothing mechanical. Otherwise the car runs beautifully. The fact that it immediately cuts off if I tap the throttle even the slightest bit and that re-snorkeling the car made it much quieter has me leaning towards some weird intake/throttle body/PCV system noise but I'm not sure what to check next.
If relevant, the car has an aftermarket exhaust and resonated midpipes but stock headers/cats.
Any thoughts? Here's a video: https://youtube.com/shorts/wvFSzaEDqjU?feature=share
alexpinson5 is offline   Reply With Quote
