Thread: Project update
Old 06-23-2026, 05:50 AM   #14
Newsguy
Originally Posted by Marc_986 View Post
Interesting to see those 997 ducts. Can you tell how they look towards radiator? Stock 986 has some awful plastic 'channel' to direct air down to a small hole as outlet. So you have modified this part, right? The balance would be between letting air into the wheel well (out of the radiator) without risking radiator damage (by stones / stuff kicked up by the wheel.
Especially interested as, so far, I have kept the third radiator out of my plans with the intention of making better use of the side radiators by improving the flow out of the radiators.
When I did this, I put some of that cheap plastic gutter guard mesh behind the radiator. Easy to cut to fit, and no additional mounting is needed. The liner mounts hold it in place.
The 987 guides are a good find!.
-H. L. Mencken
