Old 06-22-2026, 08:04 AM   #1
llonman
Immobilizer water damage
My car was left open to the elements during a severe storm and the immobilizer was damaged. I removed it and cleaned it with isopropyl alcohol and while it does behave differently, the windows will not go up or down using the switches, frunk and trunk not unlocking, nor will the car start.****
I was planning on reaching out to ECU doctors in Florida to see if they can repair or buy a used one and use one of the cloning services on ebay.
Last option is to purchase a matching immobilizer, ECU, and Key FOB from ebay. From what I have been reading I do not need the tumbler as I can add the old key blade to the replacement FOB. Is there any other part that I need? Do I need the matching signal transducer (996.618.159.01)? I noticed some sellers including the ignition tumbler, Door tumbler, and the signal transducer. Others just the immobilizer, ECU, and key Fob.
Does anyone know what else I should check for damage? There was water pooled in space below the seats. I have removed all carpet and dried it all out with fans, including the foam under the carpet which took days.
llonman is offline   Reply With Quote
