Old 06-08-2026, 01:05 AM   #1
redriver666
Question Brake wear indicator light... brake pads not worn out ?!
Last week, the brake wear indicator light came on on the dashboard Since you can't tell which brake pads are involved on a Boxster 986 (and it can't be diagnosed via Durametric either), I removed all the wheels today and visually inspected the pads. Just as I expected (I don't drive many miles a year), none of the pads were worn down to the wear indicator; in fact, all the pads still have at least 3 to 4 mm of material left before reaching the indicator To be safe, I also disconnected the plug at each brake pad to measure the resistance; a short circuit in one of the plugs could potentially trigger a false warning. Below are 3 photos of the "operation".
Questions:
1. The resistance value shown on the multimeter (for all 4 brakes) is identical to that of a new wear indicator (which I had already ordered). Does this mean there is nothing wrong with my wear indicators?
2. What, then, could be the cause?
3. Is it true that the dashboard light only comes on when there is a "closed circuit"? In other words, when the wear indicator makes contact with ground/the brake disc?
But now for question 4:
4. After reinstalling all the old pads and indicators... the dashboard warning has disappeared (for now)... :? Anyone have an explanation?
redriver666 is offline   Reply With Quote
