Old 06-04-2026, 03:27 PM   #22
Dllrd23
Originally Posted by redpepperracing View Post
9 is tachometer.
Originally Posted by BrakeExpert View Post
When you say an engine is "sideways" what does this mean? I'm not familiar with this terminolgy?
Sorry, I was trying to be funny. Usually with a V-Type engine or a straight configuration, when you get stuck oil rings that cause burning, you can pour some decarbonizing agent (sea foam, trans fluid, etc) and dissolve the build up causing the rings to stick. you cannot do that with a flat (or side to side that I called "sideways") because only a very small portion of the ring will sit in the mixture whereas you will get 100% coverage with an up and down piston. I'll stick to auto repairs and leave the comedy to the pros.
Dllrd23 is offline   Reply With Quote
