Old 05-24-2026, 06:04 PM   #4
hookoo3
I'll first start with the MAF, even tough it probably only has 10K km on it. I'll also check for air and vacuum leaks. Ai indicates that the main cause is probably the AOS. I'll replace it. The fuel system may also be a cause so I will do a pressure test and check the fuel pump and fuel filter. A smoke test is also on the list.Thanks for the suggestions.
Hookoo3
2001 Boxster S
hookoo3 is offline   Reply With Quote
