Old 05-22-2026, 08:22 AM   #10
Dllrd23
UPDATE 5/22/26: Replaced the alternator. no longer see a voltage dropout when started. the communication still drops once started leading me to believe that an ignition voltage somewhere is suspect. took a look at the diagnostic port and did some voltage readings. I found the following:
Pin 1 - 11.98V
Pin 2 - Empty
Pin 3 - K-Lead 11.7V
Pin 4 - Ground good
Pin 5 - Ground good
Pin 6 - Empty
Pin 7 - K-lead 8.6V
Pin 8 - K-Line 7.5V
Pin 9 - TN Signal - 11.4V
Pin 10 - KVA?? - 8.8V
Pin 11 - Empty
Pin 12 - Software Voltage?? - 0.4 fluctuating
Pin 13 - Empty
Pin 14 - Empty
Pin 15 - Empty
Pin 16 - 12V
Not sure what 9, 10, and 12 are. I could use some help in identifying what they are for. Without knowing, I'm going to take measurements from my other 99 Boxster and compare but in the meantime, Please help.
Dllrd23 is offline   Reply With Quote
