P2096 can be frustrating because it is often intermittent and can slip past basic tests. I would still check for a small exhaust leak after the pre-cat O2 sensor since it may only show when hot, watch live O2 readings over a longer drive for any slow or drifting response and if that looks normal, consider a bank 1 injector balance issue under load as a possible cause.
