Old 04-16-2026, 04:45 AM   #6
997_986
You could run an quality injector cleaner, it won't harm. You should pull the codes if there are any, maybe something leads you to a (starting) problem. Next question would be sparks -- you could do a visual check, but with that milage they have only 50% of their lifespan referring to the maintenance-plan. Fuel pressure could be worth checking as well.
997_986 is offline   Reply With Quote
