Old 04-09-2026, 11:18 AM   #1
Danimal
Convertible Top Struts
Good afternoon,
The gears in my convertible top transmission went out and I am trying to figure out what may have caused it. None of the linkage is jammed, but the dampers/struts are oily and suspect. I popped one off and tried to pull it apart, but it won't budge and looks as thought it hasn't been apart in ages. How hard should they be to pull apart?
Also, has anyone tried the hamburg tech replacement ones? OEM ones are pretty expensive.
https://www.pelicanparts.com/More_Info/98756158001SETHBT.htm?pn=987-561-580-01-SET-HBT&gad_source=1&gad_campaignid=22208005432&gbraid=0AAAAAD_tz53cLLkaZ0FTABEBoc9y5FpkM&gclid=CjwKCAjwnN3OBhA8EiwAfpTYeoyBtegWgZRRVddGyyOY vwkzAVFW7e83Tw4gep0XABfC7dEU4Ah9YRoC77oQAvD_BwE
Thanks!
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
