Old 04-07-2026, 06:37 PM   #1
gbp808
help identifying metal in oil sump please: SOLVED by JFPinPA
Hi, working on "preventative" IMS bearing replacement, 2001 boxster-s automatic. Turns out it is a dual row bearing and seems to be fully intact and functional. Did see metal specks and 2 slivers in drained oil so decided to check the oil sump and removed cover, not a speck of metal laying in the sump cover, but a teaspoon of what looks like mangled spring caught in the metal strainer. 2 other bits in top right, may be plastic?
Engine did make an awful noise, for the first time, as i moved it to the work area for the lift.
Any thoughts on the source of this metal, to guide me on what should be done next?
Thanks,
Garry
gbp808 is online now   Reply With Quote
