Old 03-28-2026, 09:12 AM   #6
PLP
PLP's Avatar
Originally Posted by elgyqc View Post
No I never got around to replacing it, but since I'm selling the car I may have to do this in the Spring. Hopefully others will jump in.
I am not sure if you actually did anything, but I took the risk and replaced mine.
I looked up on the eBay donor from similar car - another Boxster, 2002, S version. Close enough to mine - 2003 base.
I disconnected the battery, removed the module using pliers, and put the new one in. Connected the battery and carefully turned the ignition on. Nothing exploded, so I plugged in Durametric.
The 100 codes gone, the other codes cleared - communication is OK.
The only code I have now is 73 for the airbag deactivation - child seat. I will get to it later to see if the buckle is connected and works.
So yes, it can be done.
You can verify by VIN what the car was (donor) and find the closest specs. If you are lucky enough - it will be same components and reset will resolve all issues.
Current rides: 2003 Porsche Boxster MT (me), 2019 Bolt LT (me), 2015 Audi Q5 (wife), 2008 VW Rabbit (2.5 inline 5, MT, well, for kid... but you now, it is the 5 straight)
Previous: 2014 Fiat 500e, 2016 KIA Forte5 SX, 2016 Fiat 500X, and some old days: Trabant, Fiat 126p...
PLP is online now   Reply With Quote
