Old 03-17-2026, 05:00 AM   #5
husker boxster
husker boxster's Avatar
UPDATE
SLM, my go-to independent shop, has been doing some research on potential options. As mentioned before, options were very limited. A new one is L&N advertises a swap option on their website where you send them your short block and they send an already rebuilt engine back. You'd lose your original serial numbered engine, but at this point who cares? However, they don't have any engines on the shelf to swap, so that option is out.
After striking out repeatedly, SLM came up with this proposal: they'll pull the engine, tear it down, send the halves to L&N for new sleeves, and then rebuild the engine when the halves return. Alex, one of the co-owners, and his dad rebuilt a 997 turbo engine so they've done that type of work before. I'm excited about this option. Not sure the plan is to replace the sleeves with the same sized ones (leaving the displacement at 3.8) or if they have to bump it to 4.0. I'm fine with either.
We're finalizing details and getting me on their schedule, but that's the direction.
Qingdao - thank you for your offer. Not sure if an M96 block would work instead of my M97, but you can do what you want with it.
1989 928 S4 5 spd - black
