Old 03-11-2026, 09:11 AM   #4
CenCal Mike
My 03 had the instrument cluster lights out as well. Took the dash apart to "change lights" only to find out there weren't any to change out. The lights are built into the boards. Replaced the master light switch, after reading here and watching a couple of videos. For less than a $100, the new light switch fixed the issue. It also started giving the signal the lights were still on when the car was turned off. I hadn't noticed it had quit doing that.
Consider changing the light switch and it may solve the issue for you. Takes about 30 minutes.
CenCal Mike is offline   Reply With Quote
