Recently had the front calipers rebuilt and replaced the front brake lines from the hard lines to the calipers and the brakes I think are sticking at least as bad if not worse than they were before. Master cylinder has been replaced too and a fluid flush/bleeding has been done. Is next the ABS pump or the booster? I can't see it being the ABS sensors because they both seemed to start sticking at roughly the same time. Doesn't matter whether the car is running or off they are sticking.
