Old 02-23-2026, 12:39 PM   #79
Marc_986
Many thanks
I have seen the Roxster indeed, entertaining and informing at the same time ;-)
The pump bracket you have, where does it mount to the chassis. The front seems to mount to the little folded 'ridge' that belongs to the chassis (which would otherwise hold the CD changer or a cover). I guess it also mounts to the bulkhead side? Would you mind sharing a picture of that. I'll be in the garage tomorrow and amongst other things, intend to look at bracket options.
Would be interesting to know how the hoses work for you in the wheel well. I have decided on routing them along the battery and down where the brake rod passes. This will take it directly to the area where the steering shaft is and the hydraulic lines were.
At the position where your feedthroughs are (the strut tower), the metal also seems rather thin. Did you reinforce it with some plate or are you happy enough how it is?
Marc_986 is online now   Reply With Quote
