Old 12-18-2025, 02:47 PM   #2
BrakeExpert
Those prices are stupid, 3 grand for brakes, you know i bought my last boxster for 2900$, it needed some work like a top but it ran.
I'd do some more homework into the basics of brakes. A cursory look on rockauto showed:
DYNAMIC FRICTION 452402037 for just under 300$ before shipping, and thats all 4 corners with cross-drilled rotors, and you can go cheaper. The brakes on a boxster are nothing special, they can be changed with normal hand tools.
If you're concerned with upgrading, as I tell everyone, your tires are the only part of your car that touches the road, so your "ultimate" brake upgrade is tires, since that's always the final limiting factor. Now if you're focused on pedal-feel, using ceramic pads on "normal" iron rotors tends to give a direct feel, good even in cold weather, as you mentioned this wont be tracked. Stainless lines do give a more responsive brake pedal feedback, lots of people like them, that's worth looking into, my only suggestion is to get those without the single plastic coating, IE get rubber or something over the stainless, as the plastic tends to get hard and crack on cheaper brands like Russell (learned this years ago). You can lookup rotors, I for one have always said solid discs (over drilled and/or slotted) are best bang for your buck, the slotted ones will wear pads sooner and only are really needed on under-braked vehicles like older trucks, the 986 I would consider having good brakes for its size and weight. Cross drilling also not needed, Porsche claim they net more consistent lap times on a wet track, but on a road car, cool, but not needed (I still hear people talk about the word 'gassing' which makes me laugh.) Your brake pad choice is going to be a bigger factor in longevity and stopping grip than rotors, so go with cheap rotors, good pads, and with the money you save, put it into better tires.
BrakeExpert is offline   Reply With Quote
