Old 11-22-2025, 04:49 AM   #1
Dllrd23
Originally Posted by Danimal View Post
Since the 2.7l is variocam plus, what dme are you going to use to get it to run? The one from the 2.7l car? If so, does that work with the return style injectors and cable throttle??
It’s a 5 chain engine. (Regular variocam). It will run on the 2.5’s DME. I eliminated the rear crossover flap in the intake and used the 2.5’s wiring harness and the 2.5’s intake crossover and throttle body so I could use the cable. The fuel rail, I can’t remember what it came from either a 2.7 return type or a 3.2 or 3.4. It was 2 years ago and I tried so many different rail setups. Finally got one that worked off of a member of this forum and traded for my 2.7 returnless rail. That is the reason for the original question. When the engine was installed, I was dumping fuel on bank 2. Didn’t know if the slightly increased flow rate was the reason and all indications are that it is not. I ordered a set of new injectors and will swap out after the holidays so that I have a known good (I built a setup to flow check) to proceed with my troubleshooting. The only other thing I had to do was swap the coolant temp sensor. Basically the DME thinks it is a 2.5. It should easily compensate for the slightly increased displacement until I get it sorted. I have most of this on video if you are curious. I am not trolling for views as my videos are far from being monetized. Just did this to help a little and to have a video record of the process I followed. Chanel is here: https://youtube.com/@branchoffice1327?si=yYWvNy-YvCZwxGTH
Dllrd23 is offline   Reply With Quote
