Old 11-04-2025, 02:38 PM   #31
Marc_986
My point is that you may Not have to swap the steering rack and only have to replace the o-rings to stop the leak, awesome project, none the less :-)
Ah yes, but I'll replace it because of the play I found, not because of the minor leak. I am quite positive this is giving me the strange feel when turning. Even my wife notices it, so it is an obvious behavior.
Part number of US and ROW sway bars are the same. So i suspect parts are identical.
Please take into consideration that stabilizer mountings and linkages need to be matched to the sway bar you choose.
Thanks, that's really helpful. I'll take the front ARB of the wreck and see which size it is. For now I can only measure in the bend and that's not very accurate at all.
Marc_986 is online now   Reply With Quote
