Old 11-02-2025, 02:11 PM   #3
jluetjen
Registered Member
Yup. I put a lock-washer under each nut and it worked perfectly.
I put the car down on the tires, rolled it back to forth a couple of times and checked the right side tray with a small level. It was basically level side to side and front to back. I adjusted the left side tray the same way.
Plugged the headlight in, and everything seems to be pointed in the right direction.
jluetjen is offline   Reply With Quote
