Old 10-30-2025, 03:41 PM   #11
Marc_986
Little progress on the brakes
Left side brake is now mounted. New hose, line, caliper and disc from the wreck. Big part of the job was removing the ABS sensor. Ended up snapping it off and drilling / burning / prying it out. Luckily the new type sensors from the wreck freed up instantly. These only have four 'ribs' into the hole, so no reason to get stuck
Today I worked on the front right. Similar story, with main effort on the ABS sensor. Little setback on this side is the brake line. I can't get it separated from the hose, so I'll need to replace the line with the one from my wreck. To do so, I think the main hurdle is to release the tank strap and get the line through. Will try it out on the wreck first ;-)
I might get a chance this weekend to try and finish the fronts.
Marc_986 is online now   Reply With Quote
