Old 09-08-2025, 03:25 AM   #27
tcoradeschi
Registered Member
Originally Posted by Marc_986 View Post
So I figure the disconnected steering feel could well be a separate issue from the shake. The swaybar bushings are in pretty bad shape. And with this anti-roll bar being of the original suspension, it would make sense to fit an M030 one to go with my new M030 suspension. These bad bushings might well be the cause of the vague transition side to side.
When we rock the steering wheel violently it does sound like there is a bit of a knock. And when feeling the wheel or tyre at the same time, you can feel a boink. Do you think steering rack or tie-rods?
The only way to diagnose is to inspect. The outer tie rod ends are super easy to see once the tire is off, obviously - for the inners, you will have to pull off the boot.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
