Old 08-25-2025, 07:28 AM   #2
DanWEC
Originally Posted by maxbottomtime View Post
I say start with head unit, pccm clone would be my vote (I installed it). See how you feel then.
The stock speakers have high db sensitivity, meaning a watt of power is more efficient than most aftermarket units meant to be driven at higher watts.
If you replace your speakers, you’ll find your stereo will be quieter.
A few other thoughts: you have a line out to the factory amp already. I tried to use them with my aftermarket amp but it gave horrific interference. separate set of components run through the firewall solved that.
I went aftermarket speakers, amp, head unit, added the rear speakers and am going to put in the 997, cabrio footwell sub.
If I were doing it over again, I’d just stop at the head unit. The factory speakers were not blown, and sounded just fine in a convertible setting.
Good luck!
Thanks for the suggestion on the PCCM clone, I had no idea that existed. Looks like a great option as it looks factory and actually has knobs. Appears to have android auto as well, which is the main motivator for changing the stereo anyways. I just have to look into whether it has a microphone.
Cheers
DanWEC is offline   Reply With Quote
