Old 08-24-2025, 05:08 AM   #1
tcoradeschi
Registered Member
Originally Posted by somerled View Post
Thanks very much for the message. It's odd because the slight window drop function (when the handle is pulled) hasn't worked for years but the window seems to be seated to both avoid the frame when closing, and to stop any ingress of water/rain. So the twitching is odd because that function hasn't even worked for a long time. The window drop on the right hand side works but the window is seated too high so hits the frame when closed.
The passenger door handle does not seem floppy. If I oped the door, the window remains in place no matter whether up or down. Is replacing the door latch microswitch DIY-able for someone with basic skills and tools? Thanks.
You will need to replace the entire latch assembly, sadly. It’s not particularly difficult, but it is rather expensive, considering that the only piece which has failed is far from that.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
